Supporting guide Email ?
Hi!
Is there any guide about Email, and how to set up and configure the settings?
How can I find the URL to the webmail for a specific domain?
Ok, I can launch my webmail from my controlpanel, but is there any more friendly URL to the webmail? I?m going to set up different emails for different persons, and I would like to give them an easier url to remember. Is it possible?
And if I launch my webmail from my controlpanel, the login page says “Welcome to Horde”
Horde… Whats that? Can I change it so it says “Welcome to mydomain.com”
Check out the mail documentation at:
http://www.jodohost.com/hsphere/html/mail_overview.html
or
http://www.psoft.net/HSdocumentation/user/mail_overview.html
You can get to the various webmail choices at:
http://mail.yourdomain.com
Personally, I like SquirrelMail best. You can just create a link from your site to the webmail that you want your customers to use. There might be a cooler way to do it, like make webmail.yourdomain.com forward to the URL or do it in some weird frames or something.
The control panel launches into Horde, which is just one of the three webmail choices.
Look at this thread, too.
http://support.jodohost.com/showthread.php?t=2230
