Hey All,
I was wondering if anyone got the permision issue with this file. I have been using CSK (Commerce Starter Kit) then when we changed versions of HSphere I needed to go back into the sub directory and change the asp.net version to 2.0 (Even though it was done before the switch) and now when the store starts to load I get:
[CODE]Required permissions cannot be acquired.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Security.Policy.PolicyException: Required permissions cannot be acquired.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. [/CODE]
Now I know you are going to give me the trust level stuff but it is on a system file and not a 3rd party file:
[CODE]Stack Trace:
[PolicyException: Required permissions cannot be acquired.]
System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Boolean checkExecutionPermission) +2736869
System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Int32& securitySpecialFlags, Boolean checkExecutionPermission) +57
[FileLoadException: Could not load file or assembly ‘System.Data.SQLite, Version=1.0.44.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139’ or one of its dependencies. Failed to grant minimum permission requests. (Exception from HRESULT: 0x80131417)]
System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +0
System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +211
System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +141
System.Reflection.Assembly.Load(String assemblyString) +25
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +32
[ConfigurationErrorsException: Could not load file or assembly ‘System.Data.SQLite, Version=1.0.44.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139’ or one of its dependencies. Failed to grant minimum permission requests. (Exception from HRESULT: 0x80131417)]
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +596
System.Web.Configuration.CompilationSection.LoadAllAssembliesFromAppDomainBinDirectory() +3487289
System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai) +46
System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig) +177
System.Web.Compilation.BuildProvidersCompiler..ctor(VirtualPath configPath, Boolean supportLocalization, String outputAssemblyName) +180
System.Web.Compilation.CodeDirectoryCompiler.GetCodeDirectoryAssembly(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories, Boolean isDirectoryAllowed) +347
System.Web.Compilation.BuildManager.CompileCodeDirectory(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories) +125
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +441
[HttpException (0x80004005): Could not load file or assembly ‘System.Data.SQLite, Version=1.0.44.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139’ or one of its dependencies. Failed to grant minimum permission requests. (Exception from HRESULT: 0x80131417)]
System.Web.Compilation.BuildManager.ReportTopLevelCompilationException() +57
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +612
System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters) +456
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +3434991
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +88
System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr) +252[/CODE]
