Has anyone experienced System.OutOfMemoryException in their APS.NET applications in Win5 server?
[QUOTE=dnnportal]
Yes, I just opened a ticket.
riley
OK
We are rebooting the server now and installing a Microsoft provided hot-fix
FYI, this is the issue: Microsoft Support
Same problem was occuring last week on Win6 which we resolved by installing this hot-fix
excellent
hot-fix installed, everyhing should be running fine now
win6 is having these problems again at the moment
? I am loading asp.net properly, and without any problem. IIS has been running 15 hours straight now, that is the first time in a long time it was run that long. I will check on it
Edit: went ahead and rebooted the machine just to make sure, this is a slower time for traffic so it should not have a high impact.
-deleted-
i’ll post a ticket
Is is possible to determine what is causing the memory leak as this is occuring quite often now? Web app or OS?
As per Nagios Alert, we had only 2-3, few minutes alert on Win6 & Win5 since Aug. 5. We are monitoring these servers continously.
