Basically, tens (if not hundreds) of thousands of ASP based sites have been hit with this annoying little hack. A single Google search gives some insight into the types of sites that have been hit - many of them large, popular websites.
Anyways, I bring it up because the author in the above link mentions that this attack is the product of a vulnerability in Windows servers. A vulnerability that has been patched for, but obviously requires the necessary updating.
So far, I have had two different ASP.Net sites hit by this attack - one hosted on Jodohost, another hosted through a separate provider. Both sites employ many levels of protection against SQL injection in the code - so go figure.
Yes some have been affected but let me be clear this is NOT A SERVER vulnerably at the core. The SQL injection itself is what puts the script there, then the script itself uses a vulnerability in windows media player on the CLIENT. The server is in no way infected or at fault, it is all a coding issue.
check the database section here for some in depth discussion on it
Thanks to your suggestions, I found the hole in my code and quickly fixed it. They tried to wreck both sites again today but instead found themselves redirected to google search results on how to kill oneself. Not very classy on my part, but I guess it’s all in good fun.
