I’m experiencing issues on some sites using external services because they are disabling early TLS versions 1.0 and 1.1 due to the security issues with these protocols. This will likely become an issue with other services in the future.
I submitted a ticket (#697036) to inquire about disabling early TLS versions 1.0 and 1.1 on Win33. The response suggested that TLS 1.0 was disabled but that 1.1 could not be. If I can’t work with third party services due to this limitation on Win33, I’ll need to look at other hosting options for at least some of my clients and projects. I understand this is shared hosting but I would also expect it to be as secure as possible.
I also tested TLS on WIN33 and it appears that TLS 1.0 is still enabled:
[INDENT]“tls_version”:“TLS 1.0”,“rating”:“Bad”[/INDENT]
@Stephen I was wondering if you could weigh in on this and help me clarify the options. Can early TLS 1.0/1.1 be disabled on Win33? If not, can you explain why? Is there another server at Jodo that I could use?
Thanks in advance for any replies!
