I have a client who has had his domain on his box and had SSL certificate installed on that box. Now they want to move the certificate to jodohost servers. If I export the certificate is there an easy way for me to import that to jodohost servers?
You can send it to use. We will install it on server. But you will not able to manage SSL from CP.
Ok my ticket number is PRY-45390-108
Thanks by the way
I replied your ticket. Please check it and let us know when you done.
btw if you export it with password be sure to let us know ![]()
I did tell you the password…I might look stupid but I really am smart…at least that is what my 1st grade teacher said ![]()
sorry I did not look at the ticket since Manish was handling it, adding partially for reference if we do it for anyone else later ![]()
