I filed a TT (RS #IRV-94322-235) regarding a customer of mine. HSphere generated an over-storage limit message.
On investigating, this is what I found using HSphere generated stats from my RCP:
Nov 3
– Storage: 111MB
– Bandwidth: 630KB
Nov 2
– Storage: 111MB
– Bandwidth: 1.6MB
Nov 1
– Storage: 111MB
– Bandwidth: 5.9MB
Oct 31
– Storage: 108.4MB
– Bandwidth: 1.2MB
Oct 30
– Storage: 0.16MB
– Bandwidth: 164KB
Oct 29
– Storage: 0.16MB
– Bandwidth: 506KB
The customer has a storage limit of 100MB.
At present, there are NO files even approaching a megabyte in his FTP space. This was also true yesterday.
All of his very few email accounts are set to a 15MB mailbox limit and he downloads his mail and deletes it from the server as part of the POP processing.
This begs the questions:
– If a customer has no way to put files into his storage allocation WITHOUT consuming metered bandwidth, how did he get a 111MB file(s) into his storage when his largest bandwidth usage was just under 6MB in any one day. Indeed, ALL of his bandwidth for the relevant days is under 11MB–100MB short of what should show up if he had, in fact posted a file(s) or received a huge email attachment.
– Why is it I can’t get the Jodo techies to explain to me how this could’ve happened? The first response was, essentially: “Are you still getting overlimit notifications?” That wasn’t very useful.
When I once again posed the how and why questions, I got the “customer must’ve done it because both mail and web services are activated.” Hint: just because a service is activated doesn’t mean it’s being used. This is the case with this customer–he doesn’t have a Website. I activated Web service as part of the standard account creation process for this plan type.
– Why does it take so long to respond to a TT? The first response was about 4 hours. The second response was about 16 hours.
So…I’d appreciate an explanation of how the customer might’ve put 111MB of storage onto the server without consuming at least that much bandwidth. And if, in fact, the customer didn’t (and I have strong reasons to believe he did not), how did the error occur in HSphere? And if this isn’t a likely HSphere error, then just who did consume this amount of storage? Is there a security breach somewhere?
Charles
