I know you guys updated parts of Hsphere,but not the control panel is was deferred. When do you plan on this control panel update to finish the Patch 5 and all aspects of this update?
Alot of the Easy Apps is outdated etc.
WebD.
WebD.
Patch5 upgrade was 100% completed. It was just few changes to Hsphere DB to be done by Psoft’s Developer team, nothing related to the upgrade or anything that affects the customers. We havent said anywhere that only parts of Hsphere were updated.
We are now running the latest EasyApp package by Psoft. Also, We are not maintaining the individual packages seperately at the moment.
Oh ok Tanmaya,
The following statement at the time of uupdate confused me, saying hsphere schema has been deferred? What does that mean?
Thanks for the fast Reply,
James ![]()
Upgrade complete. Hsphere schema update has been deferred for now.
Tanmaya
Manager (Unix Operations)
As i already said it is some changes to Hsphere’s DB. In simple words, changes to a few table schema. It was posted here and deferred because it needs control panel to be down for 2 hours. I will fix another schedule with the developers soon.
