upgrade question
hey there
i wouldnt usually post this here, but i think sales has not understood my situation & questions properly.
I have a Valuehost package, which is almost full (disk space wise)
i have 41 accounts (30 included in the package) and 12 IPs (5 included) - for which i pay extra.
i noted that the value packages are now bigger than my current one (8.5GB instead of 8 ).
so i could possibly upgrade to that, but then i would lose on other ends - because the IP amount is much less (2 instead of 5), and the overage charges for it are high ($2.5/month/unit)
anyway - so i started looking into upgrading to the Silver - to get much more space, but the issue here is that i would still only get 2 IPs, so i would land up paying $70 per month and an extra $25 per month for the extra IPs i need - which is $95 - quite a lot.
so it seems that it might be worth my while to open a 2nd (new) valuehost package - just pay the extra $35 for it, and still get an extra 2 IPs for further use - which would be about $80/m.
do you see what i mean? i would land up getting much more out of it than a simple upgrade.
but in many ways its best to manage just one account - so What can you folks at Jodo say about the situation?
thanks!
I think Dipesh has tried explaining you enough in his last reply.
However, let me explain the things to you. You are currently using our Old Reseller packages mentioned at http://www.jodohost.com/sept08/reseller.asp According to this in SliverHost package you are getting :-
[ul]
10 Free Dedicated ip
60 user account
16 Gb Disk Space
240 GB Monthly Transfer
[/ul]
if you decide to upgrade the current account, you will be paying additional resources prices as mentioned on the following http://www.jodohost.com/sept08/reseller.asp
But you need more Disk Space and Monthly Transfer and want to upgrade to New SliverHost packages mentioned at Reseller Hosting for Agencies & MSPs - White Label Platform | JodoHost | JodoHost , you will be getting only 2 dedicated ip free and each additional resources will be charged according to the new additional resources charges mentioned at Reseller Hosting for Agencies & MSPs - White Label Platform | JodoHost | JodoHost
If you want to upgrade according to Old Reseller packages, you can upgrade from your hosting cp itself; but if you want New Reseller packages, then you need to send an email at [email protected] we will do as per your email.
yes, i understand now, thank you!
