Upload Components?
I’m using Windows hosting and a software package I am looking to deploye says that if I want to use it’s upload feature that one of the following components needs to be installed:
Persits AspUpload 2+
Dundas Upload 2+
SoftArtisans FileUp 3.2+
aspSmartUpload
AspSimpleUpload
Are any of these components installed on Jodo Host?
EDIT:
Persists AspUpload is available
EDIT:Persists AspUpload is available
That’s the thing, I don’t know if AspUpload is the same as AspSimpleUpload or AspSmartUpload. Are you saying they are the same and my app will work?
Persists ASPUpload is available
ASPSimpleUpload is not
