We are seeing an odd error on MSSQL8 server, it may need to have a chkdsk on reboot, it looks like some file is causing windows to say it is unreadable on logging.
It should be up within 5 minutes, windows is back up and SQL will be starting. It looks to be bit of a false alarm on the file ‘corrupt’ unreadable error, caused by a restore that failed and not an actual problem with the filesystem, still it was worth the check to ensure no long term problem.
It is all up for several minutes now.
