Using Access in Dreamweaver
I have an Access database in my root folder. I use DW MX. I am trying to connect the db in my web.
I can test locally and the pages display. When I view the remote pages the database records are blank.
I do not have a good understanding how to connect the database. I have set a DSN locally and named one through the control panel with the same name. What should the DBQ path be … /mydatabase.mdb?
Thanks for any help …
if you are using a dsn, and created in the hsphere co, it will be in the format of username_dsnname, make sure you have the prefix username_(change of course with your username) on the DSN for it to work.
[QUOTE=Stephen]
I have used the format of username_dsnname .. I still do not get the desired records to show on the web. The records display locally but not on the remote server.
It sounds like you have a problem with the DSN file path then.
[QUOTE=Stephen]
I received the path from support …
On Server its path is D:\hshome\user\database.mdb
That is the path yes, but that is not the path in the DSN setup screen, it already knows the main path, it just needs the /folder/database.mdb portion.
[QUOTE=Stephen]
I used the path as you detailed. Still did not work. How hard/easy would it be for me to use MYSQL/PHP? WOuld that be a better option for database activity on the web?
mySQL will work with access, and is a much better option for webites.
The connection wouldbe like this:
“DRIVER={MySQL ODBC 3.51 Driver};SERVER=mysqlX.servicedomain.com;PORT=3306;DATABASE=myDatabase; USER=user;PASSWORD=yourpassword;OPTION=3;”
[QUOTE=Stephen]
Thanks Stephan …
When I try to connect to database I get the error …
[MySQL][ODBC 3.51 Driver]Can’t connect to MySQL server on ‘mysqlX.servicedomain.com’ (10060)
Did you replace ‘mysqlX.servicedomain.com’ with the actual name of the MySQL server?
Sometimes easily overlooked
[QUOTE=JoCald]
uh, thanks … lol … my bad
