I was trying to get the stats via AWStats today and in it’s folder there’s just some logfiles (~2Gb) and no other files (should be some cgi/bin, .html…).
So I was wondering:
- Where can I view this statistics
- Can I transform those big _archive files to some smaller format like webalizer has (just the summaries)
Thank you for your time, Jure
You need to enable CGI Dir and add the .pl as a CGI extension for the domain from your CP, in addition to enabling AWstats in your user CP. Kindly refer to http://support.jodohost.com/showthread.php?t=1912
Hi
I am also having problems with AWStats
I have CGI enabled with .pl added. I also enabled AWStats but what I get when browsing to page is:
[FONT=Courier New]Error: AWStats database directory defined in config file by ‘DirData’ parameter (d:\hshome\reggaene\reggaenews.co.uk\AWStats) does not exist or is not writable.
Setup (‘C:\HSphere\skeleton\AWStats/awstats.reggaenews.co.uk.conf’ file, web server or permissions) may be wrong.
See AWStats documentation in ‘docs’ directory for informations on how to setup awstats.[/FONT]
please can you help.
Thank you, Rajneesh. I can now see the stats OK.
Do you perhaps know if the 2Gb file will dissapear by itself this month or do I have to delete it, and also, will the statistics stay if I delete it ?
Talawa,
I can view the AWstats for the domain reggaenews.co.uk without any errors. Check it and if you still get the error, send in a trouble ticket.
Hi
I still get an error and have sent a ticket for second time.
regards
Aron
