Using sp_addmergepublication to Create a Publication
Does anyone have any experience of setting up merge replication for SQL Server Compact 3.5 and a JodoHost VPS MS-SQL 2005 database?
Or more to the point how do I use the sp_addmergepublication to Create a Publication for such a task?
I am new to access, trying to create a database. I got
Lookup wizard to create a drop-down list box in a table,
then tried to create another and keep getting the
message, “You can only run one instance of the Lookup
Wizard at a time”. Thanks for any help
