BluJag
August 15, 2011, 8:24am
1
Websites are down - this is what I get in the Control Panel
204.xx.xx.220 (Shared IP) CHANGE to Dedicated IP
Virtual Host IP does not match DNS A Record. Probably shared IP tag was changed.
Resolve this problem
Click to get help
Name Servers
ns4.xxxxxxx.net → 173.x.xxx.5
ns3.xxxxxx.net → 173.x.yyy.5
Is this related to the server moves? If so, when will it be fixed?
Also, the Cererbrus Reseller help desk times out so can’t be reached.
Help!!
Cerberus, probably send a ticket via email as they are coming in:
Help & Knowledge Base - OPSPI Quick Start Guides | JodoHost
The server for cerberus also moved. It won’t work on two fronts like some apps.
Your IP should match…
BluJag
August 15, 2011, 9:38am
3
Will send email.
Stephen, your reply is too cryptic - what do you mean “Your IP should match”? What am I supposed to do? - everything was fine before this move to Waco
Most of my my websites have been registered with the Jodo domains service.
that IP is not moved, it is original IP, so that is why I said it should match…
BluJag
August 15, 2011, 9:52am
5
Thanks Stephen - still none the wiser - what should I do then?
I register a domain via the Jodo domain service, set the Name Servers and that should be it shouldn’t it?
I’ve emailed support as suggested.
We will need to check it, there is some chance something happened with migration tasks to make an error, we’ve seen a few funny things in the process.
BluJag
August 15, 2011, 10:26am
7
Right, thanks Stephen - I guess it must be related to the Grand Move To Waco in some obscure way.
Should I click the “Resolve this problem” link in the Control Panel, or would that make matters worse?
it won’t hurt to try, techs are trying to check it as well.
BluJag
August 15, 2011, 11:52am
9
OK, I’ve clicked the “Resolve this problem” link.
Helpdesk is up again, but refuses to recognize my login details…???
PS Needless to say, customers going ape!
BluJag
August 15, 2011, 3:11pm
10
Odd… the only remaining site still down works if the www bit is missed out. Why should this be?
