I just found out about the new Windows VPS you now offer, very neat.
WIll there be a option down the road for LInux VPS with the same set up as the Windows VPS so we could resell space etc. on Linux?
WIll there ever be H-Sphere on any VPS accounts instead of Plesk?
Thanks Guys for the new options to help us grow with you.
Yash
June 13, 2006, 10:56am
2
Yes definately, Virtuozzo for Linux with Plesk or cPanel is down the road.
H-Sphere is not a single server control panel
You can rent maybe 2 Linux VPS accounts and 1 dedicated Windows VPS account and have ur own HSphere cluster though
Can C-Panel be used on the current VPS Windows now being offered or is Plesk the only option?
Cpanel for windows is only alpha stages, and not public.
Plesk is the only option on windows VPS right now, or “raw windows”
I think I might be interested in doing this reseller option with VPS.
Will my resellers be able to be branded with there own nameservers like we do in H-Sphere with Plesk?
Will I have complete control if I start reselling or is there limitations?
WebD,
You will have complete control, the main limit is RAM.
