VPS Signup question
I’ve decided to move to a VPS solution for my clients instead of my current reseller.
I was signing up and saw this:
[INDENT]
Your own virtual mail server including 10 free mailboxes; mailing lists; mail forwarding; mailbox aliases; AntiSpam; AntiVirus; Mail SPF;
[/INDENT]
I’m confused… on my current VPS I don’t remember any limits on mailboxes?
Andy
Are you using Plesk ?for your winvps , where you are able to see this limit ?
If was on the VPS signup screen:
[INDENT]
H-SPHERE. WinVPS Value(N) plan signup
You have chosen to subscribe to the WinVPS Value(N) plan.
The plan includes:
Your own domain transferred from another provider;
Your own virtual web server (name or IP based hosting) including MIME Type;
MySQL database support
MSSQL database support
Setup Fee: $0.00 Monthly Fee: $39.95 [/INDENT]
In Window VPS Hosting we are using Hshpere to handle :
  1. Billing of your VPS account with us.
  2. shared database resources will be allocated to Hsphere, you can create database login from hsphere and use the same.
VPS Resources will be allocated in the actual VPS account we make for you. In case if you want to have more resources for your VPS account, you need to buy additional resource then only you can use the same. To request more resources or upgrade your hosting package you need to open a ticket in support.
So the limited mailboxes is only on the hsphere billing account?
You are not suppose to use Hsphere for Mailing services; but as per hsphere plan wizard limitations, we had to specify some data limit, which are currently able to see, when you try to signup.
