Web 2,3,4, MySQL 1,2 and linsd1 - Resolved
Web 2,3,4, MySQL 1,2 and linsd1 are not responding at this moment. We are checking it and will update soon.
Re: Web 2,3,4, MySQL 1,2 and linsd1 are not responding
The node on which the servers are is down and that power to server seems off and reporting failed to power on .
Will have to manually switch on the system. Stephen is on the way to do just that.
I am checking the power supply module now, as the system will simply not power on even with the remote functions working.
The lights all come on, but no fans etc.
The server is coming up after changing the power supply modular unit, I had to use a whole assembly from another chassis and it took a little longer than just a power supply swap.
due to amount of days since last fsck, it is running and on 50%.
all servers are now up and running.
All up now.
This was an odd occurrence, externally we had access to the onboard management, and things seemed ok, but the system would not start. It is however resolved fully now.
