Web2 has been Up and Down all day long.
Few minutes ago it was fixed and worked fine. Now again it’s slow and I can barely access any pages.
Could you please fix it and keep us informed about this problem?
Thank you!
It seems someone has made a faultly cronjob that is running every few minutes, we are going to suspend all cron jobs and then reactive them as they are approved valid and not causing the problem.
We have this under control now, someone has a cacheing system on their website they had running over and over and over in misconfigured cron.
Thank you for the update
Again web2 Up and Down!
Ranjan is monitoring closely, it was only very brief this time and he is watching the server.
Still see some downtime…
Also is the time on server correctly set??(
It is correct on web2 for EST(note the time changed from daylight savings to standard time back a few weeks ago)
WEB2 Down again
Its coming UP now and working fine.
________________
Akshay Vashishtha
Jodohost Support
