Hi, i just started to use your services. Do you have any options which could/would allow me to use webmail over https?
Sorry my bad english.
Well, i think that i’ll install own SquirrelMail client to ssl directory. Is that ok?
should be
am sure ive seen others say they’ve installed there own webmail clients
it’ll prob be the best way to get to work with SSL aswell
Thanks scott.
By the way, do anybody know what directory will be ssl-secured when i activate ssl-thing?
if you have ssl on a domain its on the whiole domain ie anything within the site can be secured using https.
you can require to go thruogh SSL or only directly, ie when you set https
hope that helps
Emagine: yes that hepled. There was sone confusing times when shared and dedicated ip:s was pointing into wrong site =).
Thanks again for everyone.
Next question: Have anybody installed IMP webmail program by yourself? Did you install Horde first or not?
Thanks.
[QUOTE=energed]
You can skip that. Horde is accessible from outside CPanel via http://www.nnexxezz.com/hbridge ![]()
That is made for cpanel, I am not sure it works with hsphere
yeah that might be a little prob ![]()
maybe some dude can adapt it?
