If I have some domains for which I am not using Webalizer, is there any benefit to disabling it in H-Sphere? Would that yield any kind of performance enhancement, however small? Is Webalizer something that I should keep running just in case it’s needed for a tech support issue?
I’m using Google Analytics for my purposes, so I was looking for some other things to trim where I can.
Well, I misread the page. Looks like AWStats is enabled and Webalizer is not. I’ve disabled AWStats since that doesn’t appear to be working anyway.
To make this thread not entirely worthless, is there any benefit to disabling SSI, PHP or anything else that’s not being used by an ASP.Net app?
Disabling them is less attack vector if every any botnet pointed at your site…but otherwise not much benefit
