bcandy
January 21, 2004, 3:17pm
1
Webalizer seems to create a sub directory called domain/webaliser and then updates a file called default.html
Obviously anyone that knows this, would have the ability to look at a domains webalizer results if they knew the site is hosted by JodoHost.
Is there a way of changing the filename generated or protecting it?
Yash
January 21, 2004, 5:08pm
2
Unforunately, that’s the way HSphere works. We plan to purchase Urchin 5 shortly which is far more superior. Awstats will also be available in HSphere 2.4
Nathan
January 21, 2004, 9:01pm
3
I first thought the same, but having viewed the results, I dont see that they ‘give’ anything away.
Incidentally Yash, I just love the information they do provide - and very useful.
Cheers
Nathan
Suncoty
February 16, 2004, 10:21am
4
I was looking at that default.html that gets updated and I noticed that Webalizer appears to drop off stats for days older than 8 days. Is this by design?
Thanks..
Michael
Nathan
February 21, 2004, 5:22pm
5
Also is there a way to view all of the search strings - rather than the top 20 or so?
Nathan
[QUOTE=Nathan]
Nathan
Go here…
http://www.extreme-dm.com
they have a tracker that surpases anything else. Just use this untill they get Urchin.
