A client wants to use DWMail exclusively and doesn’t want to even see the other web mail options. I proposed creating a webmail subdomain and have it go right to DWMail. Now, what’s the best way to do so? I could set up a PHP redirect, but is there a better way?
Or, is there some way I can do this with the existing mail.client’s_domain. com? I don’t see any default webmail client preferences in the control panel.
Tim
you could simply make a webmail subdomain, then make it a permanent redirect to the dwmail full url, or meta refresh/server side redirect as well.
If this is something I can do through HSphere, I don’t see how. I won’t go messing with custom DNS. I’m just going to go the PHP redirect route.
Tim
Oops, I found the HSphere Redirect spot. I’ve set that. This was the script I was going to use in case someone else finds it useful:
[PHP]<?php
function redirect($url) {
if (!headers_sent()) {
// If headers not sent yet... then do php redirect
header('Location: '.$url);
exit;
} else {
// If headers are sent... do java redirect... if java disabled, do html redirect.
echo '';
echo '';
echo '';
echo '';
exit;
} //==== End -- Redirect
redirect('http://mail.clientdomain.com/dwmail/');
[/PHP]
