hi guys,
what do u think about this site
http://www.cellphoneforums.com
i heard somany times about this site,pls let me know
mahipalreddy
hi guys,
mahipalreddy
[QUOTE=mahipal reddy]
hi guys,
mahipalreddy
First question - why the HELL did I get a “DomainNameBazaar.com” popup when I went to the site??? :nono: stuff like that makes me want to just close the window.
Second of all, it looks like you just planted a forum… Invision Power Board from the source code… what are you asking us to review here, your idea or your work on a website.
Feh, I knew I should have gone with my first instinct. If you want a review, then do some damned work. If you’re asking for a review of the color scheme, it works, there’s damn little in the way of graphics. You’ve got ads for other sites all of the place, are you looking to provide content of your own or just whore out space on your domain to the highest bidder?
Went with my initial instinct and closed the window… enough of a review for you?
I usually look at member join dates when reviews are asked if they sign up the same day or same month I usually just stay away to be safe.
WebD. ![]()
hello hatton,
thanks any way,sorry for inconvience ,pls help me what i will do on my site,can i remove my popup site,if u have any suggestion pls pass me
mahipalreddy
http://www.desiforum.com
hello hatton,
mahipalreddy
I don’t know if it’s a side-effect of being hosted at 1-and-1 or being registered by bulkregister.com.
It looks like that happens with all of the domins you’ve posted though.
Hatton
why is it that when i clicked on your link the domainnamebazaar keeps on popping??? good thing my pc has this popup blocker installed…
are you into cellphones too? i think im a member in that forum… though i dont think ive posted anythin yet…
