I am a new customer. Where do I put my own cgi exe files? I can’t see cgibin anywhere.
You need to activate CGI first:
- Click on your Domain in CP
- Click “Edit Web Options”
- Turn on CGI
- Enter in CGI directory (“cgi-bin/”)
For more:
http://www.jodohost.com/hsphere/
Hi Yash,
Thanks, it worked. But, it created cgi-bin as soon as I clicked on CGI to put it ON.
Now, I moved a cgi exe into it. But, it fails to work. Do I have to set some file or owner permissions on it? I can send you a small test for it if you want.
Sanjay
Is this a file with a .cgi or .pl extension. If you are trying to run an executable, you can’t.
