Whois reveals mysphere.biz
I don’t know if this has been talked before. I just used whois.sc to see the information for one of my domains and I see there is a line that shows this:
SSL Cert: .m***here.biz expires in 522 days
Is this normal? Is there a way to hide it? Maybe by using a unique IP?
You can try it going to http://whois.domaintools.com/ [yourdomain]
Where [yourdomain] is any of your sites hosted with jodo.
Thank you very much!
i think they tried to change most of the info to make it as anonymous as possible, but you are using the free shared SSL. you could fix that by getting your own cert, i think you can get them as cheap as $40 now…
I’m not using any SSL certs… that’s the weird thing..
Maybe this can be disabled somehow from the control panel?
it shows becasue they hit port 443 and the wildcard cert replies :frowning: No way to prevent it and have shared ssl available on any server at the same time.
Not even using an own certificate? I don’t have anything enabled as long as I know. Isn’t there a way to setup the domain not to use SSL?
