who's using my disk space
Is there anyway to see from an overview frommy reseller control panel who out of my clients is using the most disc space?
Tom
Yes, you can do a disk usage report.
Thanks Stephen … so simple when you know how!!
Yep, I went in to make sure terms were correct, (and they were) and checking out my disk usage now as well. it doesn’t break it down by domain, but by user, so it is useful to that level.
Stepehen … I have deleted a few old accounts but they show up in the report as ‘Deleted user’ … when does this disk space come back to me?
It depends on when you deleted, the usage goes on a 30 day average so until they have been gone 30 days it won’t be ‘100%’ gone from the accounting of disk space, each day it snapshots the used space, it calculated this in the ‘average’ and then of course each day that passes after the delete it will have less bearing on the used space.
Cheers Stephen … only deleted about 15 mins ago!!
