I have just converted one of my WordPress installations to WordPress Multi-Site. Everything went great with the exception of getting the site URL’s to work. The require wildcard domains to function properly, as they are all subdomains of the main URL.
Is there any way to enable wildcard domains at Jodo?
Wildcard entry is created itself by hsphere in DNS Configuration section under Built-in records, when a domain has been added. However you can check it in your hosting control panel and make sure if the entry is existed there as, *.domain or not.
Also, if the problem still persist make sure that Multi-Site has been setup correctly.
