WIn15 - Application pool issue - Resolved
[SIZE=2][FONT=verdana]Some Application pool on win15 server are crashing rapidly. We are checking it.[/FONT][/SIZE]
[SIZE=2][FONT=verdana]We checked and found issue with FastCGI, We are working to resolve it and update you again[/FONT][/SIZE]
We got the core issue resolved, but there is still some issue on the bitness making some sites with PHP not load, and trying to resolve this is an odd one.
At least not is it only those loading PHP and not all sites in the pools.
Still working on this now, PHP is running on 32bit pools, but the 32bit version of FastCGI is not wanting to load up!`
Attempting a reinstall of the FastCGI services, as nothing else seems to work, we got the crashing fixed, we got the bitness matter fixed, but php sites are still saying that FastCgiModule doesn’t exist now.
The app pools are crashing while doing this reinstall, working to be done ASAP.
The reinstall did not work as it failed to uninstall so it was not possible to ‘reinstall’ however all but PHP has been up since a few moments after the last post.
Nice, we are set now.
I feel a bit like an idiot, since there were multiple lines needing the bitness factor removed :frowning: I missed just one and it kept the php down.
