Win5 Metabase Issues
Dated: August 16, 2005
Win5 is having a # of metabase issues following the HSphere 2.4.3 Patch 2 upgrade which also caused issues earlier on Win6. We are working to revert Win5 back to the original 2.4.3 version as well as fix any sites that are down. You may notice a few IIS resets during the next few hours
Win5 went through a reboot and is performing better. We will however stop HSphere services on Win5 shortly to fix metabase corruption issues as well as downgrade HSphere itself.
You shouldn’t notice any downtime during this but since HSphere will be disabled, you will not be able to add new domains to Win5 for the time being
