Win6 sporadic problems
Win6 is giving me occassionally this error:
RCP Sever unavailable
And others related with ADO and running out of memory. Also, it’s unusually slow (I’m using a SQL Server DB in MSSQL2)
What happens?
Inka, we were already working on this issue when you reported it via a ticket
The problem is pertaining to low disk space on D:. The disk is currently being cleaned up, it should take 30 to 60 minutes and these issues should be resolved
ah that explains a prob i was getting, yup seems sorted now. :]
Would this be related?
Microsoft OLE DB Provider for ODBC Drivers[font=Times New Roman][size=3] [/size][/font][font=Arial][size=2]error ‘80004005’[/size][/font][font=Times New Roman][size=3] [/size][/font]
[font=Arial][size=2][Microsoft][ODBC Microsoft Access Driver]General error Unable to open registry key ‘Temporary (volatile) Jet DSN for process 0x7e4 Thread 0x9bc DBC 0x2e0406c Jet’.[/size][/font]
It’s in association with an Access DB … on Win6 … this problem is also sporadic, but happens daily.
Phill
IThe problem is pertaining to low disk space on D:. The disk is currently being cleaned up, it should take 30 to 60 minutes and these issues should be resolved
Ok, thanks. The problem is present since yesterday. I hope you can solve this today.
It’s fixed
The issue happens when we perform backups. We need to dump a copy of the backup on the disk before transfering it over to our backup server.
Anyway, we have sorted this out. You shouldn’t get any of those errors
