Someone has some terrible code on wincf2 that I am investigating now.
Re: WinCF2, crashing CF engine, checking
This is my TOP priority today, I will be focusing on ntohing but this until it is resolved.
it is running well for some time now, but I am keeping a very close eye.
Some problems again, the issue is with the MS Access file, there are two sites that are very busy using access and bringing the server down.
Some problems again, the issue is with the MS Access file, there are two sites that are very busy using access and bringing the server down when using ODBC connections to Access, I have sent off one email now, writing another.
I have helped one client move over to SQL and it has helped a lot in stabilizing the server.
