We are checking on it, it is down.
Re: WinSD1 down
Jodohost.com is on winsd1, and is down due to this, we are aware.
Re: WinSD1 down
nothing on KVM and nothing after reboot of the power port, so we are heading to the datacenter to check it.
Re: WinSD1 down
Will be at least 20 more minutes as there is a bit of a drive to the datacenter, JH site has a placeholder now.
Re: WinSD1 down
onsite now and checking it out.
Re: WinSD1 down
ok server is giving a beep code like memory issue, we are checking into it further.
Re: WinSD1 down
Still at it, there are some communications issues due to lack of signal on the datacenter floor on where the replacement chips are, but I think we have it sorted now and working to get them and install.
Re: WinSD1 down
We’ve changed out all the memory with no success, fearing it may be CPU or motherboard and working on options here.
Re: WinSD1 down
CPU swap did not work either, we are going for a restore at this point. Preparing machine for restore.
Re: WinSD1 down
we had backups form about 20 min before the server went down, but also have moved the HD to the new hardware and working on file restores should be much faster with this.
Windows is installing on the new hardware now, we will probably be about 4-5 hours here in restore.
Re: WinSD1 down
We have the jodohost site up a bit more than placeholder now, may not work 100% (contact form and a couple others)
Re: WinSD1 down
Windows updates going now on the new server.
Re: WinSD1 down
doing lots of reboots for the finalizing of updates now.
Re: WinSD1 down
Working on restoring the files to the new hardware at the moment, we still need to run the physical creation to make the websites, but are very close to that point. 30-45 minutes needed for data now, and then that can be run and permissions set.
Re: WinSD1 down
SQL server is completing setup, working to get DB files mounted there then we will focus on IIS settings restore.
Re: WinSD1 down
We have encountered a couple slowdowns in the iis metabase recreation, working to power through them.
Re: WinSD1 down
IIS portion is done now, one more SQL related task and we will have sites online.
Re: WinSD1 down
SQL up and sites up, the one issue I do see here is some SSL certificates may be missing, or need to be reinstalled.
Re: WinSD1 down
We are seeing some slowness. and working on it now.
Re: WinSD1 down
tried to reboot and it did not work properly, we are still working on this.
