Just got my WinVPS info and am logged in setting up getting ready to move a site to it (the old site is currently on a shared account with you guys) and I need to get ASPUpload on there. Is that something I need install do or you guys need to do it?
Also, when I “flip the switch” on my domain hosting company to point to the new server’s DNS what do I put in for a secondary DNS???
Thanks for you help in advance. Just let me know…
Thanks!
Mike Chilson
aspupload is soemthing you need to install.
There is also dundas upload which is part of their freelibs if you want to go that route.
You need to make a two DNS servers point to one phyiscal server, you can just use another IP on your VPS for this, and you can make the DNS records in the plesk CP
Gotcha Stephen…
Many thanks! BTW… Really like the VPS setup. Know you guys have worked hard to get it setup and going.
One other quick question… Is MYSQL required for the VPS system or plesk? Reason I ask is my portal will be using mssql4 and I would like to disable MYSQL if possible to conserve system resources.
Thanks!
Mike
PING… on above question… thanks!
Mike
