We are looking into an issue on WinVPS3 now itis pinging but seems some services are down.
Re: WinVPS3 - unable to remote connect
It seems like we may have a VPS with a worm that is abusing the CPU of the server causing the rest to be very slow in operating.
I have issued a reboot command to the server.
I think that the remote reboot could have down a shutdown instead fo a reboot as we lost the KVM connection an it did not some back as usual after the reboot happens. We are sending a tech to check this.
A tech will be checking the server in the next 5 minutes
For some reason we have lost the ability to communicate with the DC staff. They should be there now looking at the server.
It looks like a power supply issue possibly.
The server is coming up now.
We will be running a virus/worm scan on all VPS units. You may get an email requesting a password if yours has changed since setup.
I have checked the event viewer and I posted only a few minutes after the server had service errors. We got this resolved as quickly as possible.
Event Type: Error
Event Source: Service Control Manager
Event Category: None
Event ID: 7011
Date: 1/2/2007
Time: 8:41:48 AM
At this point all VPSes are up.
We have removed a few trojans from 3 VPSes, we will notify users whent he scan is completed on all for those that have had files flaggs as possible trojans, we only have 2 confirmed trojans.
