Is this installed on all servers?
I’m using it as it says on the website, obviously with different paths added:
Dim objZip
Set objZip = Server.CreateObject(“XStandard.Zip”)
objZip.Pack “C:\Temp\golf.jpg”, “C:\Temp\images.zip”
objZip.Pack “C:\Temp\racing.gif”, “C:\Temp\images.zip”
Set objZip = Nothing
But I keep getting the error:
Server object error ‘ASP 0177 : 800401f3’
Server.CreateObject Failed
/index.asp, line 142
800401f3
Line 142 is the line with the Server.CreateObject. I’m on win9 if that makes any difference?
Chris
from the code it looks ok, i would say its not on your server
or any server
o sorry,
it may not be on your server as you said then
no Xzip has been installed with the base install since about win14 now I am prettysure of that.
Any ideas why I can’t get it to work then, the error is making it sound like it’s not installed?
I will check it, you said win9, which may not have it, win14+ have it now.
For some reason I was spot reading a moment ago and read win19, oops!
It will be installed and ready to go in the next 12 hours there
Excellent, thanks Stephen.
Chris
djfenom
11
Hi Stephen, has this been done yet, I’m still getting the same error??
Stephen
12
Just need to do an iisreset will do it in a moment
Edit: Done now 9:39AM CST
