DNN Portal
I am trying to set up a portal in my DNN that is basically a subdomain (xxxxx.domain.com). Anyone done this? I have the portal set up, do I need to copy all of the DNN files to that subdomain directory as well? Thanks in advance!
I think that you might have to copy the files over. I did this for one of my other domains and it worked ok. And since domains and subdomains are treated the same on Jodohost, then that is what you probably have to do. If someone can tell me how to not do that I would be happy. but the files don't take that much space.
YsFred4
