Emergency Node Maintenance WINCF and WINCF3 CL1, WINCF3 up
Stephen
US Operations
Staff member
WinCF server is coming up for a moment having a blue screen then rebooting auto, in a cycle.
We are checking it now.
That failed, and I believe there is an issue on the storage or network of the node. I am going to have to take down the WINCF3 server also to ensure this, and try to make all work properly.
Changing the subject now to Emergency Node maintenance WinCF and WinCF3
WinCF3 user data is copied to new node now, logging data is still copying, once done it will be able to start up and work as it was before. WINCF is still a work in progress.
WINCF3 services will be up within 15-20 min or so, we are starting it and configuring network.
CF services aren't wanting to start up right on WINCF3, so we are checking that, while continuing to work on WINCF
I have made some changes on WINCF3 and restarted. WINCF is still some time away, may start a restore process shortly.
Well I got CF started on WINCF3, but it died upon starting the CF search services and IIS. This is a bad start to the week.
ok, false alarm it did not go down, it is up and going and services UP on WINCF3.
