Do you automatically get the dedicated ip when you sign up or do you have to ask for it
>It will be a shared IP by default, you can siwtch to a dedicated if included in your plan. The IP must be justified, for example a e-commerce site with SSL.
and are there any conditions with regards to having 3 domains on the one account.
> only that you must stay within the limits of the plan (or be changed overages) and only one domain will have a dedicated IP, the others would need to be on shared.
Does this mean 3 domain names pointing to the one website or can you have 3 separate websites?
>a pointer is an alias, and not counted as a domain. You can have 3 seperate sites.
>Can you upgrade your shared account to a reseller account at a later stage?
It is not a one click upgrade, but yes. You can sign up for the reseller plan, send a ticket that you have changed to a reseller plan, and we can then move your account into the reseller plan and close the shared hosting plan.
