mail10 hardware maintenance - tomorrow at 4:30AM EDT (GMT-4)
tanmaya
APAC Operations
Staff member
To replace in a failed drive in RAID array, we will be performing a maintenance on mail10 tomorrow early morning, starting 4:30AM EDT (GMT-4).
We will also be applying a kernel and other updates during this time.
Expected downtime is 10 minutes.
Updates are being run at the moment, further notice will be posted before the reboot.
there is an error in the disk change and I need to check it again, I am taking the server oflfine very quickly again shortly.
The problem is actually in the factory labels of port that had the failed drive. We are working around this and verifying 100% that we change the proper unit.
there is an odd issue on the network here as well now, we can go out form the server, but nothing coming in, we are checking it now.
We know the issue, main IP mounted, the shared mail IP did not, will be fixed shortly. Working KVM side can be slower than other means at times....
Server is fully up, we still need to do the final maintenance on the hard drive but it will be done on Wednesday night Sept 16th between midnight and 4:50am the 17th.
The maintenance will be done tomorrow (Sept 17), in line with the post above. The maintenance window is 4:30AM EDT to 5:15 AM EDT.
This will be starting shortly, just waiting on the shift to change so we don't have to transfer tasks.
