Anybody out there using Rainbow Portal on jodo host? www.rainbowportal.net This is an ASP.NET open source web site portal that uses MS SQL server backend.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
brawney said:Anybody out there using Rainbow Portal on jodo host? www.rainbowportal.net This is an ASP.NET open source web site portal that uses MS SQL server backend.
StPatrick said:Couldn't run it (phpNuke) on Windows (with IIS). Actually they say that they need and Apache server, not IIS
I've been through a lot since October when I started this thread. Still looking for a portal though. I'd like to stay in the MS world, particularly with an ASP.NET product. But Rainbow still doesn't have much support behind it (can't even find themes for Rainbow anywhere).martinelly said:I am running Rainbow Portal at JodoHost: http://www.lempira.net
Haven't done anything with it, however. Just testing different .net portal implementations.
I am having some problems getting CSKNET ( www.GotCommunityNet.com ) running here, however.
brawney said:DotNetNuke is moving along pretty good. They're getting ready to release version 2. But it doesn't have much support in the way of forums.
I am using DotNetNuke (on 2 sites so far) with a few C# modules I have developed and all works great! The forums I use are the Adverageous forums and they are nice...
Revision: I got the GotCommunityNet portal running on Jodohost also: http://www.ado-net.com
The problem was database-permission related.
niemeyer said:Martinelly, how did you manage to set the application mappings for your CSK portal? Is it something the support guy has to do or can you do that yourself?
Thanks a lot,
Niels
martinelly said:Support guy has to do it--it did not take very long after I sent my ticket.
thiggs said:Did you have any problems installing Rainbow on JodoHost? Got the install to work on my local machine but can't seem to install it on any remot .Net hosts.
Right now, although I uploaded all the files to JodoHost, I'm getting a generic "file not found" error page (not a .net error page). Run into anything like this?
