a few questions
very simple..
Signup -> Create DNS Zone + server aliases with that domain .
Change Nameservers at your domain registrar and update the child/private nameservers with the IPs allocated to you.
Ravi has said how to add a custom record.
to change the IP addresses asssigned to a nameserver, you need to do as i said on the previous page, regarding UK reg.
where ravi has said about create dns record, you enter the name server
ns1.xxx.com example with the IP Address you have been assigned.
you do this for ns1 and ns2
Hi
Ok, but do I sign up with jodohost using my current settings with unitedhosting, ie webtechnique.net as host site using ns1.webtechnique.net, ns2.webtechnique.net or will that conflict with unitedhosting and I have to use something else???
I apologise for trying to clarify but if I cant clarify its impossible to signup and I have to look for another hosting company.
cheers
Sure it's possible.
Though I recommend you do not change your control panel URL until your service domain starts resolving properly, or you might need some tricks to access your administrative control panel.
You can test websites beforehand by setting the HTTP 'proxy' setting in your browser to the IP of the server hosting the website you want to test (on port 80).
