Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
We need to get support to remove the fix, correct? I'm happy to leave things as they are for a little while and fortunately we don't have any customers running wp on windows servers. I did see something about returning 444 error that seemed reasonable effective and confused the bots back on the wht forumIf you feel you need to remove it, do so, but no the attacks are actually renewing a bit in the last days. Been seeing them hitting windows servers very aggressively now as well with a few others apps targeted as well
Yes, or you can do on your own.We need to get support to remove the fix, correct?
the returning non 404 was a more specific issue to nginx which had issues with the 404 handling, we were not returning 404 errors with the block in place, but 403.We need to get support to remove the fix, correct? I'm happy to leave things as they are for a little while and fortunately we don't have any customers running wp on windows servers. I did see something about returning 444 error that seemed reasonable effective and confused the bots back on the wht forum
1 . . . X
2 . . . X
3 . . . 27 ms 70.159.210.122
4 . . . 25 ns 70.159.210.119
5 . . . 29 ms 12.81.32.144
6 . . . 25 ms 12.81.32.47
7 . . . * Request timed out.
8 . . . * Request timed out.
Any updates?We will get working with them on resolving.
